drivetrain vibration
Old Jan 19, 2009 | 12:21 AM
kriesel's Avatar
kriesel
Default drivetrain vibration
my mustang vibrates pretty bad between 55 and 85, i changed both u-joints hoping this would fix it but no luck. i had to change the t-5 because it took a crap, but had the problem before this anyways so i ruled the tranny and u-joints, it does have aftermarket gears in it but that was before i owned it, the drive shaft does have some small dents towards the front yolk, any ideas guys?i have had 6 mustangs including a supercharged 90 mustang and never had a prob like this.
Old Jan 19, 2009 | 12:24 AM
FORD TOUGH's Avatar
FORD TOUGH
Has it always had this vibration? How is the tranny mount? Are the tires balanced good? If the driveshaft is dented it may not be a bad idea to swap driveshafts with another car.
Catchpole's Avatar
Catchpole
Your drive line might not be balanced any more if it's dented and all
Old Jan 19, 2009 | 12:31 AM
kriesel's Avatar
kriesel
the dents are small, but i work on a open wheel modified dirt car and have had the same prob, the right motor mount appears to be ripped all the way through, but cant tell unless i pull it
mtgldr
Feb 3, 2024 09:00 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
mdj89
Sep 23, 2015 08:49 AM
Sep 17, 2015 07:32 PM
