clean your maf, make sure the connections are clean and clear your codes. once cleared turn on your car and let idle. dont touch the gas and let it relearn. then rerun codes after its done relearning its values and see if it comes back up.
is your egr hooked up? vac leaks around egr? is the valve clean?
vac lines are fixed,and the egr is hooked up but I ain't cleaned it yet. Do I just take the bolts off and clean it or just spray somethin on it(like maf cleaner)
i cleaned mine with carb cleaner for the EGR. unbolt the EGR valve, clean the little valve make sure the little pointy deal seats flush. get all the gunk out of there.
