WTF its worse!!!
Old Jan 25, 2009 | 12:44 PM
calfroper_06's Avatar
calfroper_06
Default WTF its worse!!!
just got everything back together and the vibration comes in at 2k rpms and its a harder vibration now!!! the only thing i changed was the pilot bearing, tranny mount, and cross member bushings. i torqued everthing to spec to!! im so aggreviated, any suggestions guys?
Old Jan 25, 2009 | 12:47 PM
ctgreddy's Avatar
ctgreddy
does it do it in neutral when you rev it?
maybe its the driveshaft.
Old Jan 25, 2009 | 01:00 PM
calfroper_06
yep just sitting in the driveway give it some gas and it comes in at like 2k rpms.
Old Jan 25, 2009 | 01:36 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
was the vibration there before all the new changes???
Old Jan 25, 2009 | 01:53 PM
calfroper_06
yeah it was coming in at like 3k rpms, it wasnt like a real bad oneit would shake the shifter but u really couldnt feel it. i pulled the tranny found out the rinf gear on the flywheel wasnt pressed on allthe way, i had a motor mount nut missing, and my tranny mount was shot.
so i got the ring gear pressed all the way on and bought the tranny mount, and cross member bushings from 50resto, and no the vibration comes in at like 2k and its pretty bad, i can feel it on my butt in the seat
Old Jan 25, 2009 | 01:55 PM
mjr46's Avatar
mjr46
did you make sure it was the correct flywheel to begin with?? what about the balancer??
Old Jan 25, 2009 | 02:01 PM
calfroper_06
well no, i did pull the number off the back before install, i guess that would have bee a good thing to do seeing it was out, i have a aftermarket balancer, how do i check it?
Old Jan 25, 2009 | 02:17 PM
calfroper_06
acording to another site the flywheel is a 50oz, cast number E1ZR630 a2a
Old Jan 26, 2009 | 10:00 PM
calfroper_06
Default Update
so i put the car on the stands, started it and looked through the fork hole, and you could see the pressure plate kinda wobbling, give it gas and it would wobble harder. so i drove it real slow to the father in laws and once again started tearing it down. when we got the bellhousing off you could see there was more flywheel shoing on one side between the pressure plate bolts and the edge of the flywheel.
Here come the im so damn dumb part, there were no dowl pins in the flywheel. We got to looking deeper into what it was and you could see were the pressure plate was wearing the bolt holes bigger. so im pretty sure it was all because i had no dowl pins lining it up and holding the pressure plate in the middle to keep it balanced, ny info would be appreciated, do yall think this was my prob?
Old Jan 26, 2009 | 10:08 PM
BlessedHellride's Avatar
BlessedHellride
Are you saying that the pressure plate was offset to one side... because of the bolt holes are getting wollered out and won't hold it together? Is that what I read? If that is the case, then yes, enough weight offset to one side will cause an imbalance. I cant see why you PP is offsetting itself and your still able to shift gears. If it were me and my stuff, I'd throw that Fly Wheel in the damm garbage and get a new one.
It has been over 10 years since I put a clutch in a Foxbody, but I can't seem to recall any Dowel pins sticking out of my fly wheel when I did mine. But like I said, it was over 10 years ago and I have partied entirely to much to remember something that far back.
