will this fit?
it says up to 93. will it fit my 95?
http://store.summitracing.com/partde...9&autoview=sku
I'm also kinda mad that march doesn't make a ford style pwr steering pump bracket. I'm trying to shed the weight of those 2 giant brackets.
so what would i need? a new timing cover/water pump. anything else?
also whats the difference between the 94/95 and the fox pwr string pumps. if i convert to a fox timing cover will i be able to get the pwr steering bracket too?
depends on how far you wanna take it, you'll need the fox pump I believe and lines, not sureif you'll need adapters down at the rack but I'd do away with the a/c and buy and eliminator bracket set up for a fox. and get the fox alt bracket set up, I've never done the conversion but it should be possible.....mock it all up before you set it in
no its shipping out tomorrow. plan on having it running this weekend. so i will need a new pwr steering pump then? so i shouldn't need any new water hoses with a fox style water pump?
