havin problems fitting the hood
Old Feb 3, 2009 | 08:57 PM
86 5.0L's Avatar
86 5.0L
have you tried adjusting the hood hinges?
ALMOST STOCK's Avatar
ALMOST STOCK
From the furtherest outward point not from the bend.
Do you need that dimension?
Old Feb 3, 2009 | 09:01 PM
1988TTOP's Avatar
1988TTOP
ok i got 48 1/2 down the middle and 45 3/8 on the side
Old Feb 3, 2009 | 09:09 PM
1988TTOP's Avatar
1988TTOP
if i just sit the hood on there with no latch on hinges it is off by about 1/2 inch
Old Feb 3, 2009 | 09:34 PM
ALMOST STOCK
Then as you suspected your hood is shorter than a stock hood.
Here's another dimension
Old Feb 3, 2009 | 09:38 PM
1988TTOP's Avatar
1988TTOP
would that much make that big of deal though
Old Feb 3, 2009 | 09:49 PM
ALMOST STOCK
Your side dimension of 45 3/8" seem to be 3/4" longer than the stock hood and that will cause you problems.
Old Feb 3, 2009 | 09:56 PM
1988TTOP's Avatar
1988TTOP
would that put a gap between the hood and the cowl pannel if i push the hood up the cowl pannel the front of the hood dont line up with the bumper it will be to short
Old Feb 3, 2009 | 10:02 PM
ALMOST STOCK
That is exactly what will happen.
Old Feb 3, 2009 | 10:03 PM
1988TTOP's Avatar
1988TTOP
so it is the hood then not from when i cut the front end off then
