bushing install how to's
i am about to install bushings without a install tool. i was thinking just using washers, nut, and bolt to squeeze it in there. has anyone tried this?
or can anyone tell me how to do it with out an install tool?
BTW it is on the rear axle where the upper control arm goes.
just keeping posted. i am removing old bushings, with a pipe and nut and bolt and a washer. it is so tight in there that i pulled out the sleeve and the washer just got destroyed. laughing.
after the sleeve came out i tried it again with bigger washers and it felt like it was working, then all of a sudden the bolt snapped!!!! and sent everything flying at like a 1000mph. VERY DANGEROUS!!!!
so i just cut them out with a jigsaw and it was easy.
i will remove the sleeve on the other one as well, and just cut it out.
install was easy just did the opposite of pulling with the pipe and nuts and bolts and washers. EASY. I was able to get them 3/4 in with a bearing installer and a hammer.
