? for engine builders
I have a chance to get a a4 block virgin bore so its a 328 stroker
Virgin bore A4 block (328 ci)
Cola crank (two key ways)
Eagle rods
Probe pistions
roll master timming chain
moroso 7 qrt pan
Melling high volume oil pump
Crower severe duty soild lifters
Rolmac balancer
stock ford timing chain cover
SFI flex plate
I do not know a lot about the a4 block is it strong like the R302 that replaced it? also is it a Siamese bore or non siamese bore? what are the power limits on this block? Also this is what the guy said about the rotating assembly
Its a Cola steel crank 3.25. The rods are Eagle H-beams. I forget the details of the pistons but know they are low compression around 9.0:1 depending on the heads cc's. Will this be good to around 900 hp?
any help on this will be very appreciated the faster the better
Eagle rods
Probe pistions
moroso 7 qrt pan
Rolmac balancer
SFI flex plate
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
mungodrums
Oct 7, 2015 04:01 AM
