Lt header intall need help right now!
Old Feb 21, 2009 | 04:49 PM
9COILEDSERPENT6's Avatar
9COILEDSERPENT6
Default Lt header intall need help right now!
1991 Mustang GT 5 Spd
I am trying to install a set of flowtech long tubes,
Ok driver side do i need to take out the steering shaft?
Anything i need to remove on the passenger side.
Working on car right now!
Old Feb 21, 2009 | 04:52 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
Lt's you normally have to lossen the motor mounts and tilt the motor to get enough clearance to get them in.
Old Feb 21, 2009 | 04:55 PM
9COILEDSERPENT6
surely there is another way
Old Feb 21, 2009 | 04:56 PM
BlessedHellride's Avatar
BlessedHellride
If your header primary tubes are independent and doesn't have a flange connecting all four tubes, the steering shaft might have to go in between the middle two primary tubes. Which will be numbers 6 & 7 from the front to the rear. As stated above, loosen the motor mounts and jack the engine up as far as you can, get the headers in place and let the engine back down in the K-member.
Old Feb 21, 2009 | 05:02 PM
9COILEDSERPENT6
There is a flange connecting the tubes, Are the motor mounts the only thing i will have to unbolt?
Old Feb 21, 2009 | 05:04 PM
FivePointOhh
in limbo
yea you just loosen them up and jack up the motor. you have to get it pretty high to get some clearance. only do one side at a time.
Old Feb 21, 2009 | 05:07 PM
9COILEDSERPENT6
Alright thanks a lot i'll give it a try
Old Feb 21, 2009 | 05:12 PM
AdderMk2's Avatar
AdderMk2
Banned
drivers side goes in easier from the bottom, and the steering shaft has to be removed...
you would be much better off if you got rid of those ****hole headers
Old Feb 21, 2009 | 05:13 PM
9COILEDSERPENT6
Where do place jack on motor
Old Feb 21, 2009 | 06:00 PM
9COILEDSERPENT6
yes where?
