Thread Lock manifold studs
Old Mar 9, 2009 | 08:57 PM
pastfast125's Avatar
pastfast125
Default Thread Lock manifold studs
Hey.
I was removing my upper track heat intake, and the studs from the lower turned out. Is it ok to red thread lock the studs into the lower to prevent this from happening in the future?
Old Mar 9, 2009 | 09:01 PM
mustangsneverdie's Avatar
mustangsneverdie
If I used any threadlock on thm bolts it would be the red
Old Mar 9, 2009 | 10:45 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
do not use threadlocker expecially red on 5/16 intake bolts, you retorque them after a few hundred miles and that's that.
Old Mar 9, 2009 | 11:34 PM
pastfast125
ok. Any idea on what to torque em to?
I'm selling the intake and I want to make sure the studs are in the way they should be before I ship it out.
Old Mar 9, 2009 | 11:35 PM
mjr46's Avatar
mjr46
lower manifold to head is 19-24 ft lbs I believe
Old Mar 9, 2009 | 11:46 PM
pastfast125
ahhh no you're thinking a different bolt than me.
I'm talking the STUDS that are in the lower intake that the upper intake bolts to. There are 4 studs in the top of the lower intake, the upper intake sits there and 4 nuts go on.
Old Mar 10, 2009 | 04:51 AM
302army187's Avatar
302army187
in that case I would use the thread locker
Old Mar 10, 2009 | 06:27 AM
Portmaster's Avatar
Portmaster
Why torque them down? the guy who gets it is just going to have to remove the nuts before he installs it. You don't want to thread lock the studs into the lower intake. If you ever have to remove the studs it may very well bring the threads out with it. On aluminum I use antiseize when putting steel bolts/studs into aluminum. The torque will keep them in place. Snug them down a little for shipping and send it on it's way.
Dokilar
15
Oct 16, 2015 08:13 PM
KingRando
Oct 2, 2015 08:06 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:58 PM
