Cam Help
Old Mar 10, 2009 | 02:03 AM
interwest's Avatar
interwest
Default Cam Help
302 (92 GT HO) bored .030 over and fully balanced, hypereutectic pistons, scorpion rocker arms, SFI flexplate, FR valve tappets, FR e-303 camshaft, hardened pushrods, Trickflow Twisted Wedge heads, FR aluminum dual plane intake manifold (port matched), Holley 600 cfm Carb, Mr. Gasket electric fuel pump, Flowtech LT headers, true 2 1/2" dual exhaust w/ Flowmaster 40s, MSD 6AL box blaster coil and wires, Edelbrock gear drive set, aluminum radiator, Ford 9" rear end with 3.89 gears and a spool, disc brakes all the way, on MickeyThompson ET Street Radials 235/65/15 out back and BFG 205/65/15 out front. C4 auto trans.
No power steering and no ac.
NOS nitrous kit in the coming weeks.
Everything is in the car except the rear end and 2 1/2 exhaust (currently on 1 3/4 w/ 2 flows) which I hope to get done in the next two weeks and then take it to get dyno-tuned.
Now I would like to take this car into the high 11s N/A if possible and w/ nitrous maybe low to mid 11s, any cam recommendations? I know my weak spot is the FR e303 cam in there right now. Thanks in advance.
Old Mar 10, 2009 | 07:04 AM
Portmaster's Avatar
Portmaster
Dump the Ford Racing Dual Plane intake (it's crap) put a Edelbrock RPM Air gap intake on with a 650 DP Holley, Comp Cams NX274HR cam and throw the Gear Drive in the trash in favor of a quality chain. Limit your squeeze to a 100 shot with those pistons. You will need about 2400 stall
Old Mar 12, 2009 | 02:07 AM
83gtragtop's Avatar
83gtragtop
bump.
Old Mar 12, 2009 | 06:54 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
junk the cam, gear drive and carb set up and or port your current intake
Old Mar 12, 2009 | 02:16 PM
83gtragtop's Avatar
83gtragtop
What cam do you recommend?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
