Overheating problems?
Old Mar 10, 2009 | 07:01 AM
Wickedways's Avatar
Wickedways
Default Overheating problems?
OK, I can't figure it out. I've installed an electric, fan 3-row aluminum radiator, 160 degree thermo, a summit waterpump and the damn thing is still getting hot! It started leaking out of the hose that goes into the thermostat housing. Help anyone!!
Old Mar 10, 2009 | 10:19 AM
capri debris's Avatar
capri debris
Although it's not causing the overheating, a 160* thermostat is way too cold and should be changed. Running lean or having your timing set too high will cause engine temps to skyrocket.
Old Mar 10, 2009 | 10:36 AM
Slo5oh's Avatar
Slo5oh
Banned
Have you tried not using a thermostat? If so, does it still overheat then?
Whats your engine combo?
Old Mar 10, 2009 | 10:42 AM
capri debris
Not using a t-stat is one SURE way to make it overheat. With no t-stat, the water is circulating too fast and doesn't stay in the radiator long enough to get cooled down and temps climb.
Old Mar 10, 2009 | 11:26 AM
xxxmustangtxhc's Avatar
xxxmustangtxhc
i have a 160 t stat in mine and my car runs fine with no problems at for the last 3 years and im running a turbo car... might have blown a head gasket. even if you dont see water in your oil you can still have one.... thats another reason for overheating
Old Mar 10, 2009 | 11:56 AM
steel1's Avatar
steel1
Possible air trapped in the cooling system.
Old Mar 10, 2009 | 12:56 PM
luckythirteen13's Avatar
luckythirteen13
take the thermostat out and drill a small hole in it (around 1/16") towards the top of it. this will let air out of the motor more easily.
check your compression and make sure you havent blown the gasket
Old Mar 10, 2009 | 02:12 PM
mustangsneverdie's Avatar
mustangsneverdie
you could have something blocking a water passage in the motor.I remember having a piece of rtv blocking a passage in my car at one time
Old Mar 10, 2009 | 05:53 PM
Wickedways's Avatar
Wickedways
Is there any way to get air out of the cooling system without drilling a hole?
Old Mar 10, 2009 | 08:26 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
^^^turn the heater on, once you get good heat, air should be out
