Supporting Mods
Old Mar 10, 2009 | 10:13 PM
USMC1775's Avatar
USMC1775
Default Supporting Mods
For a turbo running anywhere from 5-9 psi, what do you guys suggest? So far -
-42lb injectors (big enough?)
-Calibrated MAF (90mm?)
-bigger fuel pump (225lph)
-FPR
-colder plugs (what range)
-Msd box (6AL)
Im planning on picking up one of the boost bros kits and swapping in a Turbonetics turbo and wg since I have friends.
Old Mar 10, 2009 | 10:34 PM
USMC1775's Avatar
USMC1775
So Summit makes 42lb injectors, but only makes a MAF for 36's
Old Mar 10, 2009 | 10:35 PM
primetime5.0's Avatar
primetime5.0
get a 95mm PMAS for 42's
Old Mar 10, 2009 | 10:50 PM
USMC1775's Avatar
USMC1775
Where? And so 42s would be the right size then?
Old Mar 10, 2009 | 11:01 PM
primetime5.0
actually your probably going to want a blow thru maf
http://www.jdsperformance.com/index....&inmake=0&pg=2
Old Mar 10, 2009 | 11:09 PM
USMC1775's Avatar
USMC1775
Yeh want but for 265+shipping is it required? I priced everything out from Summit for just under 8 bills, just as a kind of ballpark for myself. I guess tomorrow Ill start looking around a bit for better prices. If anyone knows of good places or has suggestions on parts, PLEASE chime in.
Old Mar 11, 2009 | 01:35 AM
primetime5.0
only because i <3 you
http://www.buyfordracing.com/shop/pr..._id=635cPath=9
Old Mar 11, 2009 | 09:04 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Primetime is on time. I think I would stick w/ the blow thru though.
Old Mar 11, 2009 | 09:49 AM
AdderMk2's Avatar
AdderMk2
Banned
definitly go with the Lmaf setup... however, let me forewarn you... you CANNOT run it in your car without having a chip burned
Old Mar 11, 2009 | 10:12 AM
luckythirteen13's Avatar
luckythirteen13
80mm blow through maf from pmas-try andersonfordmotorsport.com
42# injectors
255lph walbro intank pump
msd 6al, dont get the 6a, it wont allow you to add a 2 step in the future if you so decided
