Vacuum lines help
Old Mar 26, 2009 | 02:32 PM
ibayter's Avatar
ibayter
Smile Vacuum lines help
Hello Guys, I was changing my plugs and I broke 2 of my vacuum lines since the plastic were all dry, question, where can I find them here in Canada, I went to dealer, parts source they do not carry them, I went to look for them in a junker I found some but they are a little bit bigger, will this make a diference? Please let me know. Thanks in advance for your comments.
Old Mar 26, 2009 | 07:44 PM
87foxgt's Avatar
87foxgt
any mechanic should have them or know where to get them. If that doesn't work out for you use the internet...
Old Mar 26, 2009 | 07:46 PM
89musclestang's Avatar
89musclestang
nope as long as it seals tight and you have no leaks your good...
Old Mar 26, 2009 | 09:28 PM
mustangsneverdie's Avatar
mustangsneverdie
and you can always go to a parts store and get some rubber hose to put over the plastic pieces
Old Mar 26, 2009 | 09:29 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
just go to your local parts store and get some rubber vaccum line that slides onto the hard plastic portion where it broke off and run the new line with rubber hose
Old Mar 26, 2009 | 09:30 PM
mjr46's Avatar
mjr46
lol...you were 1 click faster than me = you beat me to it
Old Mar 26, 2009 | 09:48 PM
mustangsneverdie
that's the only time I'll ever beat you lol
Old Mar 26, 2009 | 11:22 PM
mjr46's Avatar
mjr46
^^^^^^^^^^^lol, nah, you'll beat be I'm sure again
Old Mar 27, 2009 | 12:01 AM
q8stang's Avatar
q8stang
broke the hose?? if so then any rubber hose will work
Old Mar 27, 2009 | 06:35 AM
ibayter's Avatar
ibayter
Ok Guys thanks for your feedback, I went to get some in the junker yesterday but my idling problem still the same it goes up and down, I notice that it is doing that when the charging neddle goes below the 1/2 gauge mark, could be the alternator ? because I did change the spark plugs and replaces the Vacuum hoses and still the same, any ideas what should I do ? I hate to go to the mechanic to find out it was a little detail and pay at least 80 dollars ! I am trying to avoid it ! LOL.
