Rear end
I've been hearing noises which i assumed were coming from the rear end so i jacked it up today and was messing around with the tires and it seemed one was a lot looser then the other. I was thinking the limited slip was going out but i dont know a whole lot. So if anyone else has any ideas let me know.
Thanks
Thanks
If the axle tube stays still and the axle shaft can be wiggled, then you have a bad outer axle bearing. If you're getting the "one wheel peel" at the track, then you have worn clutches in the differential. Either way, it sounds like that whole rear assembly needs some major attention.
Replace all the bearing in the rear. Unless you go to the track every weekend with slicks on you can make the 28 spline stuff last for a lil while. I would just upgrade the diff clutches to carbon fiber and replace all the bearings. Make sure it hasnt damaged the axles if the outter bearings are bad.
i was thinking about putting a locker in but not sure really on what to get. would this be good enough for what i have
http://store.summitracing.com/partde...82+4294839047+
