Supercharger?
Old Apr 22, 2009 | 03:02 AM
grey90stang's Avatar
grey90stang
Default Supercharger?
I was thinkin of buying a remanufactured paxton 6psi for $1500. i mostly have bolt on still stock h/c/i. Want more hp but have to pay labor since i dont have room or time to do anything. heads and cam install is $3600 with parts. Labor for sc install is $1000. also a daily driver with 4.10 gears and aod. Think i should do it and buy 24# injectors? And will the motor be fine if the compression is still good?
Old Apr 22, 2009 | 07:30 AM
kweb288's Avatar
kweb288
what model is the paxton?
You may want to think about going with a Vorech V1 (run around 1800). Your motor will be fine, and with such low boost you should be fine with an FMU calibrated to you stock 19# injectors but youll need to get a fuel pump to be on the safe side
Old Apr 23, 2009 | 06:46 PM
grey90stang
Im getting 30# injectors, have the 190lph fuel pump, and possibly getting the bbk ssi intake manifold before install. what do you think aboout the bbk ssi intake manifold
Old Apr 23, 2009 | 07:33 PM
USMC1775's Avatar
USMC1775
Junk intake
Old Apr 23, 2009 | 08:48 PM
kweb288's Avatar
kweb288
agreed you can do A LOT BETTER then that
Old Apr 24, 2009 | 01:41 AM
luckythirteen13's Avatar
luckythirteen13
where in ca? who's doing the install?
Old Apr 24, 2009 | 10:53 AM
USMC1775's Avatar
USMC1775
haha lucky thinking that would be an easy G huh?
Old Apr 24, 2009 | 11:53 AM
luckythirteen13
nah id cut him a deal LOL
Old Apr 25, 2009 | 03:15 PM
grey90stang
Im in san jose, someone wants install for 1000 but might do install by myself and looking at the vortech v3 self lubricating so I don't have to do the oil lines
Old Apr 26, 2009 | 10:53 AM
kweb288's Avatar
kweb288
oil lines arnt horrible to do. Just the hole in the oil pan makes you a lil nervous.
That would be a good unit to go with! not to mention that its brand new so you know what you have
