I have a piece bolted on my throttle body that is slotted that you can bolt your TPS sensor to so you don't have to dremel out the holes in the TPS Sensor. I was adjusting my TPS down and tightened it too much and cracked the side of this spacer thing.
I can't find one anywhere on the internet does anyone know what I mean or where I can get one?
try ford, take the part to the dealership, tell them what you have and see if you get lucky.... otherwise the only other place i see you finding one is the junk yard
if its an aftermarket part, then call the company that makes your after market part... and tell them what you broke! cant tell you to much without pics
.... why would you spend time and $$ in something that does not net any gains whatsoever. Adjusting the TPS closed position signal voltage is a myth. Make sure it's within its spec window (.6 - 1.1 vdc) reset the system and let the EFI EEC do its job.
