How high?
What do you mean by rev? When the car is neutral and you are just free revving it? Or do you mean when you are actually driving. When I drive I go to 6000rpm under full throttle, but I do have "stock" internals. I never free-rev the motor, unless I am trying to figure out a problem with the motor.
when it was still a stock type short block we would rev it to 6800. then moved it back down to 6200 but I did see 7500 a few times in the burn out box and a few times when the shifter was having problems. But we did have a good rod bolt in the rods. we also run a EPEC tuner so we can move the rev limiter where we want.
I mean while in a pull (acceleration) how high has your motor tached? Im not a fan of free revving..You are just asking for trouble in my eyes when you do that,and when I mean relatively stock Im meaning stock rods,crank and internals
pretty much stock with gears, trans swap, e303 springs roller rockers, and pushrods (fooling around with my buddy) i accidently forgot to shift....... needless to say i hit 7200 before going "O $H!T!!!!!!!!!!!!!!!" and shifting
that was one time, over a year ago and the car still runs fine! i usually shift around 6200 now
