When
Old Apr 28, 2009 | 10:12 PM
gt884me's Avatar
gt884me
Default When
I have just had my 302 converted to a 347 stroker with lots of parts...my question is its an 88gt with speed density, i* am converting to mass air, but the engine needs to be run for a little while to check for issues....is it safe to wait a little while to convert it or does it have to be done right away?......Thanks
Old Apr 28, 2009 | 11:24 PM
AdderMk2's Avatar
AdderMk2
Banned
good luck getting it to run on the SD setup... that should be interesting
Old Apr 29, 2009 | 07:07 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
you should of converted it long before installing the stroker
Old Apr 29, 2009 | 04:54 PM
gt884me's Avatar
gt884me
Thanks for the great answers.....thanks....my plans didnt involve stroking it, we found problems in the bottom end after removing the oil pan for a rear main leak..so now I have a stroked engine with a comp cam afr heads and s.d. obviously i know i need to convert it...but the engine hasnt even been started since the rebuild..so can i convert it now and then fire the engine up?
Old Apr 29, 2009 | 05:01 PM
67mustang302's Avatar
67mustang302
I wouldn't try to run it on the stock SD setup.
Old Apr 29, 2009 | 11:13 PM
mjr46's Avatar
mjr46
YOU COULD BUT NORMALLY , That's a mod I'd of done before installing a new motor, meaning I'd of gotten the car to run right on the maf conversion, because now the issue you could run into if you don't get the maf conversion in exactly right, it may not run at all or run right and ten you'll second guess yourself about what the problem may be....either way what's done is done so go for it now
Old Apr 30, 2009 | 07:42 AM
Portmaster's Avatar
Portmaster
Carb it!!!!!!!!lol
Old Apr 30, 2009 | 06:23 PM
gt884me's Avatar
gt884me
Thumbs up
Originally Posted by Portmaster
Carb it!!!!!!!!lol
You know i has actually thought about it, but ive got so much money invested in the manifold, mass air and crap i might as well use it
Old Apr 30, 2009 | 06:35 PM
HACKGT350's Avatar
HACKGT350
im with you port carb that thing lol. might as well just convert to maf and then run her.
Old Apr 30, 2009 | 06:54 PM
mjr46's Avatar
mjr46
sell the efi stuff and use that money to convert to carb..lol
