tires rubbing
Old May 12, 2009 | 10:40 PM
90orangenotch's Avatar
90orangenotch
Default tires rubbing
i have eibach drag launch springs and no front sway bar on my notch with et streets and its rubbing a lil on the driver side. any ideas how to fix this? it did rub once on the passenger side but i just added air to the bag on that side.
Old May 12, 2009 | 10:50 PM
AdderMk2's Avatar
AdderMk2
Banned
drivers side what?
Old May 12, 2009 | 10:56 PM
90orangenotch
its rubbin on the inner fender lip
Old May 12, 2009 | 11:01 PM
AdderMk2's Avatar
AdderMk2
Banned
well congradu-friggin-lations...
how about you tell us if its front or back
your never going to get good information here if you dont GIVE good information.
not to mention, your sentence structure sucks
Old May 12, 2009 | 11:09 PM
90orangenotch
It is rubbing on the driverside rear inner finder lip. I figured u would think its the back since i said i had to add air the the passenger side bag.
Old May 12, 2009 | 11:28 PM
AdderMk2's Avatar
AdderMk2
Banned
i knew exactly where you were rubbing... the problem is that you, being the new guy around here, like all new guys, did not give enough information.
It is not uncommon for foxes to sit low on the drivers side. What kind of wheels are you running, what size wheels, what size tires?
the more information you give, the less posts like THIS, you will see
Old May 13, 2009 | 02:50 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
take a base ball bat and a hair dryer outside
take the hair dryer to heat up the paint(to try to keep from breaking it)
then take the base ball bat and stick it in the fenderwell and roll the car forward to make more room for the tires to fit
Old May 13, 2009 | 07:28 PM
nacanitihs's Avatar
nacanitihs
i just took a mini sledge (3lb) and worked the inner fender lip up. gradually
Old May 13, 2009 | 07:37 PM
Portmaster's Avatar
Portmaster
Adder if you were as smart as you are rude you would have an IQ of 300.
To the OP, in the future when you ask a question be as specific as possible and it will keep the E thugs off your back.
Old May 13, 2009 | 07:40 PM
cch's Avatar
cch
I understand the weight savings of taking off the front sway bar, for drags.. but why keep it off permanently? Definitely creates a significant amount of roll for a street car..
