EV1 v. EV6 injectors
Aside from the connection, and the slimmer body of EV6 injectors, waht is the main difference between the two? I have a buddy that says you can spike the fuel pressure higher on the EV6's, and that the new style is more reliable and clogs less than the old blue tops etc. Is this true?
I need to get a set of 24#ers and he has them in ev6 used, but i would want to get them serviced and sonic cleaned/tested before i put them to eliminate any future headaches, and in the long run it might not be cost effective. I found a new set of ev6 24#ers with the connector adapter for $195. and I may be able to trade for them.
Any opinions or knowledge on the subject? Thanks.
HC_CrAzYHoRsE
Jun 21, 2007 02:40 PM
