Speedo needle bouncing?
Old May 28, 2009 | 11:19 AM
1987notchback's Avatar
1987notchback
Default Speedo needle bouncing?
how do i fix my speedo needle from bouncing? a friend told me to tighten my speedo cable? is this true if so how do i do that? thanks mike
Old May 28, 2009 | 11:39 AM
87GT Drop Top's Avatar
87GT Drop Top
You need a new cable.
Old May 28, 2009 | 12:01 PM
1987notchback
Default ?
Is it hard to replace? this is a dumb question but it is the cable that connects directly into the back of the gauge cluster? i only ask bc i just replaced my gauges and fear i will have to pull them out again it was bouncing with the old gauges too. thanks mike
Old May 28, 2009 | 12:50 PM
67mustang302's Avatar
67mustang302
Mechanical? Take the cable out, pull it apart, clean it and oil it, and reassemble it. If it still bounces then it's the little plastic gears int he speedo itself, so you'll have to pull and disassemble the dash to get at it, but if you don't fix it and the gears get beat up, it'll bounce forever.
Old May 28, 2009 | 08:20 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
most of the time I have found it to be the speedo itself
Old May 28, 2009 | 09:36 PM
67mustang302
Yeah, dirt and crud gets in the little gears and prevent them from turning smoothly, and mechanical speedos are VERY sensitive to extremely slight motion.
Old May 28, 2009 | 09:47 PM
Explosive's Avatar
Explosive
Mine bounces, the only cure I've found is to peg it. doesn't bounce when it can't go any farther lol.
Old May 28, 2009 | 10:11 PM
nacanitihs's Avatar
nacanitihs
mine bounced and i changed the speed sensor where the cable attaches to the tranny and it fixed it and my cruise control..
http://www.autozone.com/autozone/cat...questid=819797
Old May 28, 2009 | 10:50 PM
tohoopty's Avatar
tohoopty
this is true.i changed out my 85 mph for a 140 and the 140 bounces pretty good but the 85 never did.but the 140 looks better so i'll deal with it.
Old May 28, 2009 | 11:05 PM
mjr46's Avatar
mjr46
that's cause most of the 140 mph ones were 85 mph cores converted to 140 mph..probably didn't bother to check it out and test it when they converted it
