0 compression
Old May 29, 2009 | 05:25 PM
ballajb's Avatar
ballajb
Default 0 compression
I have zero compression on my motor right now. What are the top things that i need to check? Oh by the way someone did some motor work on the car such as cam, new rockers and pushrods. Could it be because the pushrods are not long enough or too long? or maybe rockers are down too tight?
Old May 29, 2009 | 05:32 PM
ryan_89_mustang's Avatar
ryan_89_mustang
....wow
Old May 29, 2009 | 05:40 PM
redpony88's Avatar
redpony88
i would START by removing the valve cover and inspecting... then unbolt the rockers so you know the valves should be closed. then do the test again?
0 just kinda sends a chill down your spine....
Old May 29, 2009 | 06:16 PM
AdderMk2's Avatar
AdderMk2
Banned
i'd have to say too long pushrods, PTV wasnt checked, and possibly bent valves
Old May 29, 2009 | 06:22 PM
67mustang302's Avatar
67mustang302
+1
Maybe if you were lucky the pushrods were just too long or the rockers are too tight, and your valves are ok.
mustangsneverdie's Avatar
mustangsneverdie
^^^what he said
Old May 29, 2009 | 06:23 PM
AdderMk2's Avatar
AdderMk2
Banned
hopefully its just the pushrods... sometimes you get lucky and PTV issues bend pushrods...
but I like being pessimistic
Old May 29, 2009 | 10:00 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
remove all the rockers and push rods and do a leakdown test, you'll need a specific tool/ gauge for that, based on the results this test renders you, you'll know if the valves are bent by where you hear the air hissing from and the percentage of leakage per cyl the tool registers
Old May 29, 2009 | 10:03 PM
67mustang302
Pessimism usually turns out to be correctism, unfortunately.
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
