problem found....
Old Jun 25, 2009 | 04:41 PM
Shelty's Avatar
Shelty
Default problem found....
seem to have located the source of the problem, well the mechanic did... my parents took my car to their mechanic, cuz they got tired of me screwing with it I guess I dont know, I slept in, and there was a note on my desk saying they took it down there...
mechanic called, the intake gasket failed by one of the runners... so Ive literally got a huge vacuum leak, which is what is causing my MAF to read low voltage and is causing the car to run lean..
told me they can replace them for cheap... I dont really feel like doing it, so whatever...
Old Jun 25, 2009 | 04:45 PM
FuzzyDiceRule's Avatar
FuzzyDiceRule
nice at least its an easy fix, not one that requires a new engine (/rage)
Old Jun 25, 2009 | 04:55 PM
Shelty's Avatar
Shelty
that is a good thing to know
what of your brother's 347 tho? not building that up?
Old Jun 25, 2009 | 10:51 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
glad to hear it's nothing major
Old Jun 26, 2009 | 07:17 AM
capri debris's Avatar
capri debris
You let the rents take your car to be diagnosed and fixed... while you sleep in?!?!
And you call yourself a Mustang enthusiast. Tsk-tsk.
Sounds like you suffer from "coddled youth syndrome." LOL.
Old Jun 26, 2009 | 08:07 AM
302army187's Avatar
302army187
I wouldent pay someone for a intake manifold gasket.
that's $30 in gaskets max, and 3hr's of work max.
easy stuff.
i know how it feel's, i poped a intake gasket when i had a little back fire, and it sucked trying to figure it out. once i reolized what happened i felt dumb
Old Jun 26, 2009 | 08:27 AM
aode08's Avatar
aode08
Don't feel dumb, most of you guys don't see the volume of problems like a Mechanic does, nor have specialized training and machines.
Even the most experienced Mechanic would have trouble finding the vacuum leak at the EGR SOLENOID housing(below the black cap), if you run into that one, common ISSUE.
I use the smoke machine with vapor dye and a UV light, to find vac leaks very easy, the same principal(dye) for oil leaks, and coolant leaks and EVAP issues
Old Jun 26, 2009 | 01:02 PM
NotchAbove's Avatar
NotchAbove
Those lower gaskets are pesky little ****'s.
Old Jun 26, 2009 | 10:34 PM
Shelty's Avatar
Shelty
coddled youth? haha I wish...
this is the first thing they have done for me in a while... they were tired of me taking up the garage and borrowing their cars... (I didnt want to drive my car a whole lot)
and I slept in becuase it was my first day off work in 9 days...
but anyway... I dont really have the time to do it myself anyway... been working way too much...
Old Jun 27, 2009 | 03:23 AM
302army187's Avatar
302army187
well i should be getting the **** on my car soon. so you can use that extra cash to buy the same stuff i did if it works out well for me
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
