bumped timing up.
Old Jun 29, 2009 | 03:14 PM
tohoopty's Avatar
tohoopty
Default bumped timing up.
i just bumped the timing to 14 degrees and what a difference it made.i know its a useless thread just wanted to share.
Old Jun 29, 2009 | 03:30 PM
r1sky5.0's Avatar
r1sky5.0
Is that timing safe for my 87 to run? If so what kind of gas do I use?
Old Jun 29, 2009 | 03:53 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
i was up to 16* without issue on my old build. 89 octane.
Old Jun 29, 2009 | 04:37 PM
AdderMk2's Avatar
AdderMk2
Banned
advancing your timing will only add power to a certain point. Anything past 15° usually makes no difference in power
Old Jun 29, 2009 | 05:09 PM
domindart's Avatar
domindart
Im at aprox 17* now. Still going to play w it. I run 93 when tuning timing, but will try running 87, some people say run a lower octane cause thats what these cars are made for, but someone else says 93 or high octane is needed when advanced timing.
Old Jun 29, 2009 | 05:17 PM
r1sky5.0's Avatar
r1sky5.0
So what do you guys recommend when it comes to choosing the gas?
Old Jun 29, 2009 | 05:29 PM
domindart's Avatar
domindart
Im no mechanic by far, but I was reading around and I got two different answers, some said run low octane (87), some said run 93. I think you can run 87 on the car if you want to, but Ive always run 93, and last I heard you should run higher octane if your car is advanced. Thats what Im doing now.
Old Jun 29, 2009 | 05:37 PM
Iroc's Avatar
Iroc
yes if u advance timing extra octane is needed so as not to allow detonation
Old Jun 29, 2009 | 06:00 PM
r1sky5.0's Avatar
r1sky5.0
ok thanks you guys. I also heard if you run 87 with advanced timing, you get pre ignition. What happens during pre ignition?
Old Jun 29, 2009 | 09:59 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you have 2 flame fronts that are burning and start melting things :P
