will this be streetable (daily driver)
Old Aug 6, 2009 | 11:28 PM
60trimGT's Avatar
60trimGT
Originally Posted by FivePointOhh
lol, dont worry about questions i dont mind. ill answer what i know.
yea im hoping hoping hoping for a 11.99 or faster on my set up, or at worst with nitrous getting me there.
i edited my post and added a picture for you. i like visuals. i take pictures of everything
you seem like you know your ****, think this will hit 12's?
compcam 1.7 rockers
65mm tb
bbk lt's
mac o/r h-pip
mac pro dumps
k&n drop-in
3.73's
eibach drag springs
are caster camber plates needed for the eibachs?
Old Aug 6, 2009 | 11:29 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
no but mine came in the kit.
build you suspension better, stickier tire and you'll get close if its a 5 speed. at least mid to low 13's
Old Aug 6, 2009 | 11:34 PM
60trimGT's Avatar
60trimGT
i'm thinking adding the 90/10 50/50 set up with SFC and the UPR contro arms with maybe a set of mt et streets to the combo above will hit 12.9 or atleast a low 13 on a 5spd. the only worry is will the t5 hold up to those crazy launches on mt's and will the rear end last also?
Edit: rear seats, jack, spare tire will come out and the smog pump will be bypassed also if that helps
Old Aug 6, 2009 | 11:37 PM
FivePointOhh
in limbo
dont launch super hard. there really isnt a need to decimate your transmission. high RPM roll out and you only lose like 1-3 tenths IMO depends how aggressive you are on the roll out through the beams, especially if you stag deep and at good with the lights.
but yea just count on low 13's at least with gears, suspension work and a good sticky tire on stock motor. with a good base to go off, you can only get faster
Old Aug 6, 2009 | 11:40 PM
60trimGT's Avatar
60trimGT
awesome man thank you very much. i been following your build thread btw good job bro
Old Aug 6, 2009 | 11:52 PM
60trimGT's Avatar
60trimGT
88 5.0 lx don't have 8.8 rear ends right?
Old Aug 7, 2009 | 12:21 AM
AdderMk2's Avatar
AdderMk2
Banned
yes they do. all v8 stangs post 85? had 8.8's
Old Aug 7, 2009 | 12:23 AM
60trimGT's Avatar
60trimGT
alright thank you
Old Aug 7, 2009 | 07:44 AM
Tony71502's Avatar
Tony71502
Strange 10-way adjustables are what I'm using in the rear. KYB's are a decent bit stiffer than stock. I've still got them up front because I don't plan on replacing them until I go to a coil over.
If you get springs, get caster camber plates. If they come in the kit, great, otherwise make them part of your purchase. You will regret it if you do not, as the stock caster camber plates can barely keep a stock suspension stang aligned.
Old Aug 7, 2009 | 09:37 AM
w8less's Avatar
w8less
compcam 1.7 rockers
65mm tb
bbk lt's
mac o/r h-pip
mac pro dumps
k&n drop-in
3.73's
eibach drag springs
i dont see what adding a gt40 set up what hurt to achieve your 12's goal and its cheap
