Teardown weights
now these were done with a bathroom scale some i am sure they arent as exact if i were using a shipping scale from work
bumper support 15lbs
deck lid w/spoiler 30lbs
wiper motor 2.5
rear springs w/spacers 5lbs each
stock rear control arms 5lbs each
stock 7.5 drum to drum 160lbs
cruise control 4lbs
horn 1lbs
stock struts 16lbs each
racecraft c/c 2lbs both
strange struts 9lbs each
team z k-member 10lbs (weighed the best i could on the scale)
a-arms 3-4lbs both
steering shaft 1lbs
bumpsteer kit 1lbs
drop spindle 5lbs each
coilovers wsprings 2lbs each
motor mounts 2-3lbs both
torque link 1lbs
17in 94-95gt rims w/ bfg radials 37lbs
17in 00-02gt tims w/ daytona tire 42lbs
16in fox pony's 40lbs
rear seat 30lbs
drivers seat 38lbs
passenger seat 30lbs
arm rest 8lbs
rear bumper support 30lbs
wiper motor 2.5
cruise control 4lbs
horn 1lbs
a-arms 3-4lbs both
steering shaft 1lbs
bumpsteer kit 1lbs
torque link 1lbs
rear seat 30lbs
drivers seat 38lbs
arm rest 8lbs
we can do that once i get a bigger list together if youd like. i still have my pony's with tires so i can weigh them. then i also have a set of waffle rims 02 gt rims and a set of 18in saleens. i also have a stock radiator that i can compare to my aluminum radiator
how much does the stock K-member weigh?
Weighed my street and drag wheels / tire set up the other day
OEM 10hole rim's with 215/60/15 street tire's weigh just over 45lb each, my weld drag lite rear tires with 235/60/15 micky thompsons ET streets where 40lb's
I was pretty surprized my tiny *** street tire's on stock rim's were so heavy compared to a "race wheel" with decent sized drag radials
