B303 on stock heads
Keep your stock cam. it provides loads of low end torque, which a stock 5.0 needs. The B-cam is outdated and does not make power till 4000rpm+, well above your heads flowing limit. Sure your car will sound good, but it will run like crap and chances are you will experience extreme valve float with the stock heads and springs. The Cobra intake is a good intake. It is much better than the stock H.O. intake. It will give your car much better breathing in the upper rpm, even with the stock heads and cam.
Care to say more? And The intake is going on even if I don't have the heads or a new cam. Cams aren't expensive so I figured I might as well get one. This is no track car I want lots of torque, top ends not as important. You just have to beat people from a stop on the street lol so any suggestions??
oh and cam swaps require spring upgrade...I have over 700.00 invested in my cam and all the proper valvetrain hardware so this cam lives up to it's expectations, iF YOU intend to achieve the same from spending 169.00.....lol better research a little more
Ok well with FR cams out of the questions I might go with a comp cam. And before i got around to getting the new heads I would have installed....3.73's, alum driveshaft, bbk long tubes/h pipe, already have flowmaster cat back 2 1/2, 65 mm tb, new maf, the intake, and control arms/ subframe connectors. So that's where I am at this point, whats should the next step be.
