svo heads?
Old Sep 19, 2009 | 11:54 AM
beaky73's Avatar
beaky73
Default svo heads?
hello to all, the motor i took out of my 91 gt has SVO heads and an e303 cam. are they good heads and is it a good cam? the motor has a 347 stroker kit in it. also the guy told me he runnning 14 degrees of timing, is that to low? and last, what is a arburn positive traction unit. is that a specfic brand?
thanks to all....
Old Sep 19, 2009 | 12:32 PM
AdderMk2's Avatar
AdderMk2
Banned
thanks to all....
The heads are good, but not for that particular engine setup.
the cam however....crap. get a larger set of heads and a custom cam, and the car will thank you
Old Sep 19, 2009 | 02:48 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
^^what he said
Old Sep 19, 2009 | 08:32 PM
beaky73's Avatar
beaky73
hello to all.... i took the whole motor apart and this is what i found. the motor had 4 bent push rods and one of the rokers had some chips on it. should i replace the rocker? also i dont think the motor had a 347 stroker kit in it after all. this looks like a stock pistion. could some one tell me for sure. last one of the valves is beat up.
Old Sep 19, 2009 | 08:52 PM
mjr46's Avatar
mjr46
those look like stock pistons for sure...... as for rockers check and make sure they weren't hitting the valve covers
Old Sep 19, 2009 | 09:01 PM
beaky73's Avatar
beaky73
that is what i thought..... should i replace the rocker?
Old Sep 19, 2009 | 09:04 PM
mjr46's Avatar
mjr46
check the cup where the push rod seats, if it's fine and the oil hole is clear then I'd reuse it
Old Sep 20, 2009 | 08:38 AM
beaky73's Avatar
beaky73
thanks for all the help... i am going to put the heads on my buddies 87 gt. he said he will take them. i am going to get a 347 stroker kit, what are the best heads, intake,and cam to get to maximize the motor. the car is going to be a weekend driver, never going to race it. also i want a cam with a nice lope to it. thanks to all.
Old Sep 20, 2009 | 02:13 PM
lxman1's Avatar
lxman1
I like the Holley Systemax II kit myself.
Old Sep 20, 2009 | 03:46 PM
mjr46's Avatar
mjr46
what are the best heads, intake,and cam to get to maximize the motor. .
that is the classic question of all time..lol, depends on your budget, ??? what are the hp goals/power output???, I could recommend a few options but if it's out of your financial reach
, the recommendation will do you no good
