Any Problems with this Build
Old Oct 27, 2009 | 06:51 PM
Curtis75's Avatar
Curtis75
Default Any Problems with this Build
I am trying to build up a motor for a friend. I'm new to supercharged motors but I'm going to give it a shot anyway. I will be running a Vortech supercharger putting out 10psi max. The car is an 87 converted to Mass Air and bone stock right now. I will be rebuilding the long block to stock specs which should make the CR 9:1 from what I've read. I would like to run Comp Cams K35-306-8, 284/290* .533/.544". I will upgrade to #42 injectors. I will be running stock heads with bigger springs and the stock intake. MLS head gaskets. BBK shorties and no cats. Will this cam be too big? I am not sure where I could get it tuned around London ON either. Sorry for all the questions TIA
Curtis
Old Oct 27, 2009 | 06:57 PM
motorman524's Avatar
motorman524
MF Informant
Yes you will need a bigger fuel pump. I think that you can go up to .520 before you hav ptv clearance issues but that may be wrong.
Old Oct 27, 2009 | 06:58 PM
mustangsneverdie's Avatar
mustangsneverdie
Originally Posted by Curtis75
I am trying to build up a motor for a friend. I'm new to supercharged motors but I'm going to give it a shot anyway. I will be running a Vortech supercharger putting out 10psi max. The car is an 89 converted to Mass Air and bone stock right now. I will be rebuilding the long block to stock specs which should make the CR 9:1 from what I've read. I would like to run Comp Cams K35-306-8, 284/290* .533/.544". I will upgrade to #42 injectors. I will be running stock heads with bigger springs and the stock intake. MLS head gaskets. I am wondering if I should upgrade the fuel pump. Will this cam be too big? I am not sure where I could get it tuned around London ON either. Sorry for all the questions TIA
Curtis
89's were already mass air.your definitely going to have to upgrade the f/p and if i were you I would find another intake for sure
Old Oct 27, 2009 | 07:16 PM
Curtis75's Avatar
Curtis75
Sorry its an 87, the mass air is from an 89. I would like to get an intake but not my car or budget, and at least its easy to swap later. Most of the cams I find on Comps site are .533, .544 lift the smallest dual profile cam I can find is .512/.533. I just noticed the S/C kit came with a pump so ignore the fuel pump comment.
Old Oct 27, 2009 | 10:51 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
what's the rest of the build??
Old Oct 27, 2009 | 11:29 PM
nacanitihs's Avatar
nacanitihs
well the sc comes with an inline pump? ull need to upgrade the one in the tank as well. 255lph
he can pick up a cobra intake or explorer one cheap and they are the same thing basically
Old Oct 28, 2009 | 05:07 AM
Curtis75's Avatar
Curtis75
Im not sure what else I can tell you its a small rebuild on a budget so most things are going to be stock. It does have BBK shorties and no cats. Im not sure what else your looking for.
The car is an 87 Cobra GT. Will this be the cobra intake your talking about?
Thanks
Old Oct 28, 2009 | 09:55 AM
motorman524
MF Informant
There is no such thing as a Cobra GT. There were no Cobras in 87 either.
Old Oct 28, 2009 | 01:14 PM
mustangsneverdie
in Canada gt's are called cobras
Old Oct 28, 2009 | 01:15 PM
mustangsneverdie
Thanks
no he's talking about the 93-95 cobras
