Which Cam Should I Get
I really dont have $300 for a cam I didnt want to spend more then $200 thats why I was looking at the trick flow or another E cam but the trick flow specs looked better then the E cam
Sounds like you basically just want us to pick between a TF stg1 and an E cam... in that case, flip a coin, they both suck.
well how bout this comp cams XE270HR-14 it has
Basic Operating RPM Range 1,800-5,800
Intake Duration at 050 inch Lift 218
Exhaust Duration at 050 inch Lift 224
Duration at 050 inch Lift 218 int./224 exh.
Advertised Intake Duration 270
Advertised Exhaust Duration 276
Advertised Duration 270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.512 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.512 in.
Valve Lift with Factory Rocker Arm Ratio 0.512 int./0.512 exh. lift
Lobe Separation (degrees) 114
I have 1.7 roller rockers and AFR 165s with 550 max lift springs will this work if I dont go over 5800 rpm sorry I dont understand the spring rates how they work I was never told just trying to learn and make the right choice thanks for your help
