Heater question.
Old Dec 18, 2009 | 08:10 PM
Cocolroo's Avatar
Cocolroo
Default Heater question.
Just changed my heater core in 86 mustang.Got lucky and did it through the glove compartment.Problem is it didnt make any improvement much over the old one that took forever (15 min for a little heat)Blower fan does work though.
Im getting air through my vents but very little
So maybe my old core was ok after all.
I know it takes about 15 minutes for temperature gauge to reach halfway so
could it be my thermostat that is the problem or if it was my thermostat would temperature go up at all.
What about a heat control valve or is there one.
Thanks as Usual.
Old Dec 19, 2009 | 12:04 AM
94ford5liter's Avatar
94ford5liter
did you check your vacuum lines in the engine bay? There is a plastic line along the firewall that controls the vents. If that is broken or has a hole in it, your vents won't work or just blow very little air.
Old Dec 19, 2009 | 04:31 AM
Cocolroo's Avatar
Cocolroo
Does anyone have a picture of which one that is on a 86 mustang gt?
Old Dec 19, 2009 | 05:41 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Is the car reaching operating temp? Are both heater hoses getting hot? Are all the vents working correctly when switched? It might just be a t-stat problem.
Old Dec 19, 2009 | 10:33 AM
Cocolroo's Avatar
Cocolroo
It takes about 15 minutes and then the temperature reaches the halfway point. Seems to take a little long.I will check and make sure both heater hoses are getting hot.I can feel heater core gets hot for sure and fan motor is blowing but im getting no hot air through vents.My blend door works but the foam around it is not that great.
On the diagram which is the vacume line in the engine bay that could be broken.The one that says from manifold that goes into check valve.Is that check valve the same as a heat control valve.
Sorry about all the question but my chilton manual doesnt explain CHIT!
djbigskrilla
Sep 20, 2022 01:04 AM
tmdm
May 2, 2021 02:49 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Seanam
Oct 4, 2015 10:15 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
