electrical issues =[
Old Dec 25, 2009 | 12:22 PM
sc0braj's Avatar
sc0braj
Default electrical issues =[
recently, my 90 5.0 has been having a hard time charging.. and it'll ALWAYS need a jump when trying to start. doesnt matter if i JUST turned it off or if it's been off for a day. and i noticed most of the gauges except RPM, temp, and MPH are raised alot! the Volt Amp reads 18+ volts while im driving and it flucuates as well.. the fuel gauge is wayyy past Full but for sure its no where near full.. i know its not the battery because i used my friends newly purchased battery from autozone. i was thinkin alternator?
Old Dec 25, 2009 | 12:40 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
have the alt tested, and if it's overcharging, it'll boil the fluid out of the battery and then not only will you need a new alt but by now the battery could be toasted, have both tested
Old Dec 25, 2009 | 12:44 PM
sc0braj's Avatar
sc0braj
you're right.. i was just about to edit my post saying that battery fluid is dripping all over the place.. but the battery still works good.. =] thanks
Old Dec 25, 2009 | 12:53 PM
mjr46's Avatar
mjr46
replace the alt before driving it anymore or the battery will be toast....sounds like the voltage reg went SNAFU....
Old Dec 25, 2009 | 10:41 PM
sc0braj's Avatar
sc0braj
is the overcharging the reason why my fuel gauge is way high?
chrisdbassplayer
Oct 13, 2015 06:53 PM
Dathan
Oct 5, 2015 05:52 AM
LiquidDrink
Sep 29, 2015 10:06 AM
mrappe
Sep 26, 2015 10:16 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
