3g alt
Old Jan 7, 2010 | 08:41 PM
lx5.0's Avatar
lx5.0
Default 3g alt
my altenator went out, and i guess im going to upgrade to the 3g, anybody know of a good place to order one from
Old Jan 7, 2010 | 08:51 PM
motorman524's Avatar
motorman524
MF Informant
First read this to make sure you get everything for the conversion.
https://mustangforums.com/forum/5-0-...lkthrough.html
Any parts store will have the alternator.
Old Jan 7, 2010 | 08:52 PM
mattdel's Avatar
mattdel
Local junkyard, or just go to autozone and get one. there is a huge list of ford cars that come stock with them.
www.lmgtfy.com
Old Jan 7, 2010 | 09:35 PM
lx5.0's Avatar
lx5.0
well ill probably just get one from junkyard cause i need my car for work and school and i dont think i can wait 1 week if i order one online, ok so by reading on that write up i leave the d plug alone which is going to connect to 3g and i cut other connector with 3 wires which has the two fat wires and the little black\white stripe, and i need a stator plug to connect that black\w-stripe wire and i connect other 2 fat wires with a terminal ring and is going to go connected to stud in back of 3g, and i run a 4 gauge also with a fuse to starter solenoid is this right
Old Jan 8, 2010 | 10:29 AM
Tony71502's Avatar
Tony71502
Yes, that's correct. Your belt should work since the pulley is not that much different in diameter. But just in case keep in mind you may need a belt change to get the proper tension.
Old Jan 8, 2010 | 01:03 PM
lx5.0's Avatar
lx5.0
thanks for info everybody i just installed the alt i was able to find a 3g alt with the factory harness in the back so i didnt have a problem installing it. Now next on my list is installing an electric fan
Old Jan 9, 2010 | 01:00 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Yup, gotta love the junk yard performance! I'm going to be doing my 3g upgrade for less than $20 .
Old Jan 10, 2010 | 12:23 PM
lxman1's Avatar
lxman1
^^ I did
Old Jan 10, 2010 | 09:40 PM
r1sky5.0's Avatar
r1sky5.0
What other car besides the sn95's came with 3g alternators?
Old Jan 11, 2010 | 01:07 AM
projectresto83
M.A.D. Motorsports
Here is a list of vehicles that have the 3G alternator, most are 130A, but some might be 110A:
94-96 Mustang 3.8 V-6
94-95 Mustang 5.0
94-96 Thunderbird 3.8 V-6 (non SC)
95-96 Windstar 3.0 V-6 (most are 3.8's)
93-96 E/F series Trucks/Vans 4.9 L6*
96 Sable 3.0 V-6
94-96 Cougar 3.8 V-6
*Probably the best one if you can get it (should be easy to find, too) is off the E/F series...this series uses a
threaded top ear like the stocker on the Mustang....E/F series with threaded ear uses metric bolt. ALSO, make sure
the E/F series is 130 Amps and NOT 95.
**Thanks mattdel for this information you gave me a few years back.
