need some advice
Old Jan 17, 2010 | 10:34 PM
87bruiser's Avatar
87bruiser
Default need some advice
ok im new here so i will say hi to everyone first...now to the point...i have a 88 5.0 5speed and i need to regear the rear end to wake the car up some more and dont know what to put in it....and also the engine is built and was wondering were someone would guess the hp is at i have 289 hi-po heads shaved, 2.25 in. intake 2.125 in. exaust, ported and polished, full roller setup, 1.7 ratio rockers, intake is ported, stock throttle body, cold air intake, tuned long tube headers to 3 in. exaust,
every cylinder is exactly the same from flow in to flow out same psi same distance exaust port to tip of tail pipe, runing a 12.5 : 1 CR....all the answers i can get will help so thank you
Old Jan 17, 2010 | 10:51 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
and how did you get that big of valves in 289 heads?? seeing is how a 1.94/1.60 set up has the valves nearly married to one anothers seats
Old Jan 18, 2010 | 10:26 PM
MustangBradley's Avatar
MustangBradley
Those valve sizes are more for a 429, not a 289.
Old Jan 18, 2010 | 10:45 PM
87bruiser's Avatar
87bruiser
ill get the pictures to prove it when i pull the heads and freshen the engine this spring...now back to the topic what do you all figure it is puting out?...and the valves are just about touching
Old Jan 21, 2010 | 09:35 AM
19905.0stang's Avatar
19905.0stang
if u want a new gear go with a 3.55 or 3.73 that will wake it up
Old Jan 21, 2010 | 09:55 AM
capri debris's Avatar
capri debris
With valves that size, my guess is about 1000+ hp at the front wheels... and with power like that you don't need to worry about better gears.
I'm sorry, that was just rude.
LOL.
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Shadow7874
Sep 24, 2015 09:06 PM
2k232
Sep 16, 2015 10:28 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
