with gt40's your peak hp is not going to be to much higher then stock, probably just over 5k, so you probably wern't going to make much more that that even if it did keep climbing.
you are going to lose a ton of power to the wheels because trucks have more rotating mass, but you should still be making atleast 240-250hp I would think..... |
i think we found the prob.. the total timing of 30 degrees is very low... it should be around 36 am i correct??
I'd check ignition system first. Check ad vance rates too.....
valve train is wrong, my bet.
Originally Posted by FivePointOhh
(Post 6761218)
Originally Posted by PRO50SC
(Post 6759274)
So you built a motor that's no better then stock.
LMAO, yeah those numbers are way low. My stock 93 put down 202hp and 268lbft of torque with high flow cats. You've got something up. |
gonna dyno it soon..
carb is tuned timing is good 36 total timing valvetrain cheked out good. its way more powerfull now i feel it.. should be making atleast 260 + now |
Im gonna say valve train as well R/T restriction in the high rpm areas AEB bad dyno numbers
Originally Posted by 5.0kid
(Post 6851851)
not being a smartass.. just asking..:icon_confused: |
How soon is your timing coming in? It should be at full advance by 2500 RPMS if you are going with top performance. Sucks that the numbers where low on the first one.Good luck!
