thermostat question
Old Mar 7, 2010 | 04:53 PM
87MustangLX's Avatar
87MustangLX
Default thermostat question
My car runs at 160 in winter while driving 55 but on idle it will over heat if i dont flip the fan on. during summer it will overheat either way if i dont turn the fan on. im not too sure if i even have a thermostat. any ideas?
Old Mar 7, 2010 | 04:56 PM
Mustang Boy's Avatar
Mustang Boy
Cool
sounds like you dont have a thermostat at all i would go buy a stock replacement from the parts store and stick it in there and see if that helps at all
Old Mar 7, 2010 | 05:45 PM
MustangBradley's Avatar
MustangBradley
Any car will overheat while they sit still if the fan is off. Air flow through the radiator is needed to remove the heat from the coolant that is generated by the combustion taking place in the cylinders.
Old Mar 7, 2010 | 06:22 PM
87MustangLX
yea i thought so, basically the only way to find out is to check the thermo eh
Old Mar 7, 2010 | 06:54 PM
RogerDodger1's Avatar
RogerDodger1
Is the O.E. radiator fan shroud still mounted on the radiator?
An engine needs a thermostat to operate properly, so check that.
Old Mar 7, 2010 | 10:35 PM
OnyxCobra's Avatar
OnyxCobra
Really shouldn't go any cooler than a 180 t-stat if you get one.
Old Mar 7, 2010 | 11:05 PM
capri debris's Avatar
capri debris
He speaks the truth... no colder than 180*
A cold engine wears quicker than one in a "normal" heat range.
Old Mar 7, 2010 | 11:33 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
also at 190 stat the ecm retards timing 2 degrees as read in the map tables for spark advance vs temp, where as a 180 stat pulls no timing in the map tables at said temp
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
