91 5.0 idle poblems please help
Old Mar 7, 2010 | 06:11 PM
c4king's Avatar
c4king
Default 91 5.0 idle poblems please help
whats up fellas? hey i just bought a 91 5.0 well, id say it had a 4cyl to start but itnow has a 5.0 fuel injected, mass air, stock t/b and mass air meter, new iac motor, it has a cam the guy told me it has a e-cam but i built the 87 5.0 i had and used a b-cam and this car i have now thumps harder than a b-cam, but anyways maybe someone can help me here, this car has a very nasty idle surge, i tryed a gasket off ebay that has smaller holes than the o.e.m gasket, i set the t.p.s @ .99. i have tryed all that i know that fixed my last mustang from the surge butthis one is being a pain in the a_s.... if anyone has any idea what it may be or know of anything i can try or buy or fix to make it stop or even get a little better than it is.. and also when driving and coming to a stop it will stay at about 2500 rpm for a few seconds before it starts to fall off to a idle. thanks for any input.
randy
Old Mar 7, 2010 | 06:25 PM
87MustangLX's Avatar
87MustangLX
hmmm, does the car want to die when you cold start it?
Old Mar 7, 2010 | 06:30 PM
c4king's Avatar
c4king
Default idle
yes it dose, its a bitch to start ,like a carb car thats cold natured..
Old Mar 7, 2010 | 06:35 PM
87MustangLX
well i have the same problem. its probably the iac valve, its on the side of the throttle body. You might need to clean it or get it replaced
Old Mar 7, 2010 | 06:40 PM
c4king's Avatar
c4king
nope, its new !!!!!!!!!! try again
Old Mar 7, 2010 | 06:53 PM
dreamer1uk's Avatar
dreamer1uk
Did you do a base idle reset? Vacuum leaks??
Old Mar 7, 2010 | 06:55 PM
87MustangLX
well another problem would be the throttle body plate. its a part inside the throttle that flips open when you press on the accelerator and the amount it opens depends on how much you press the accelerator.
Well just like the IAC when the throttle body gets gunked up with carbon it can stop it from closing all of the way causing idle problems.
Old Mar 7, 2010 | 08:41 PM
raftdaddy's Avatar
raftdaddy
+1 on the throttle plate.it may be just set wrong.if it closes to far the engine opens it up then lets it fall back again hence surging. just try to turn in the little screw to hold your plate open. on mine it took only two turns in and car runs/idles perfect. you may still have an ecam.if your timing is off it can sound pretty lopey.
Old Mar 7, 2010 | 08:58 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
run a koer test and check for codes first.
Old Mar 7, 2010 | 11:05 PM
Five0hFox's Avatar
Five0hFox
I don't understand why no one does this. It only makes since to check codes because it might tell you what your problem is. Removes a whole lot of guess work.
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
svfetter
Oct 5, 2015 11:39 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
