Rebuild planned for this summer
Hi guys, i have a 1994 Mustang GT, lookin to rebuild for major HP. I do live in CA, but hopefully goin away soon, so im not interested in following 50-state policies on parts.
So far my part ideas include
-AFR1388- 185cc Cylinder Heads
-Ford Racing X303 Cam
-Ford Racing Hydraulic Roller Lifters (.874 lift)
-Ford Racing 24 lbs. injectors
-BBK MAF- CAI/24 lbs tuned
-Holley Systemax 5.0L intake manifold
-Professional Products 70mm TB
-1.7 Trick Flow roller rockers
1) do any of these parts not work together? Do i have enough clearance? Im looking to use stock block, and possibly stock pistons if they can handle. And i was looking more at the parts, and im worried that i have too much lift for the heads. not sure though.
2) do i need to upgrade any other parts? (pistons, Pushrods, etc.)
3) am I missing anything for a major engine rebuild? lol.
Feedback is greatly appreciated. =]
whats your budget & goal?
if i the money i would do a turbo kit and you would have money left over for suspension mods... kweb288 is right with a little bit of boost goes a long way... google B and G turbo kit i have heard some good things about them
MY friend just tore apart his 89 5.0 motor, and found forged pistons as a factory part, is this true with my motor, or would i need to swap out pistons to handle? anything at all id need to swap out and handle? because i've also seen suggestions on other posts for fuel injectors and MAF when adding a supercharger. Thanks for the input. =]
if spending this amount of money, why not get the most of it?
TW FAC 190's
custom cam
TFS-R intake
90mm MAF and TB
36-42lbs injectors
1 3/4 LT's 3" collector
3" exhaust flow through mufflers
4.56 or 4.88 gears
suspension from dave Z from team Z
tuning equip to top it off or custom tune...
...try not to pee your pants.
TW FAC 190's
custom cam
TFS-R intake
90mm MAF and TB
36-42lbs injectors
4.56 or 4.88 gears
