Vacuum lines Help!!
so ever since i bought my mustang i have been putting new brakes rearend blah blah blah. but i have not addressed my vacuum lines that are missing until now, so i feel lik this is common sense and i should know it but i do not. 2 of my vacuum lines from my t-fitting are not there... where do they go to? i have looked in my repair manual but no luck... i would appreciate u guys help thanks mike
great thanks that def helps. when i was double checking under the hood i also noticed what appeered to be a nipple for a vacuum line comming off of my throttle body it did not have a hose or one of the rubber ends on it... it is an aftermarket professional products throttle body, any idea what is supposed to be there? thanks for your help mike
here are pictures of both my t fitting and my throttle body. the only thing that might not be right on the t fitting is the ac being capped? also should i put hose clamps on the caps or are they ok on there own? in the other pic i think you should be able to see 2 capped nipples and one open on the throttle body. thanks again mike
the nipple on the TB is supposed to have a hose running to the oil fill tube (if you have stock valve covers). I guess it's supposed to act as a secondary PCV setup....mine is capped, and I run a crankcase evac setup.
The things on your vacuum tree that are capped is the vacuum supply for your HVAC, the vacuum supply for cruise control, and I can't remember the third. There are embossed letters on it that say what they go to.
Since I bypassed it all, like yours is... I just ran a hose from brake booster to the intake manifold and got rid of that plastic vacuum tree.
