Spark????
What replacable parts control spark besides the coil, dis, and ecu... Just asking to know... Sorry if it seems like a dumb question just trying to learn
thanks
Gary
ooo and were is it located and how to replace it if needed.... If there is anything else
thanks
Gary
Well the backfiring issue when the motor is cold is back but hit And miss... I replaced my IAC, ECT, and ACT... I was asking about ignition stuff so I can start researching it... My fuel is good so I thought I would start with learning ignition stuff so when stuff goes wrong I'm prepared.... And it has no codes, I've cleaned the maf
Thanks
Thanks
It's when I put a load on the car it back fires alittle and stumbles do to it but you can drive right through it and it goes away with more throttle also I've changed the fuel filter and it only happens when the car is cold
