Strange electrical issue
Old Apr 24, 2010 | 02:20 PM
Lazor05's Avatar
Lazor05
Default Strange electrical issue
So I just hooked up an aftermarket tach and I have created a very strange electrical issue. I used the power from the radio since it is hot when the car is on and then grouded it to the same ground as the radio. Well my turn signals both work when the headlights are off. But whenever I turn the headlights on, or even the driving lights, my right turn signal doesnt work. My left still does but the right turn signal turnns on but it does flash just a steady light. So somehow I bypassed the flasher for the right turn signal. How on earth did I do this?! Or is it just a coincidence and its something else. Also whenever I unplug the tail light fuse the right turn signal will flash. I dont understand whats going on. haha
Old Apr 24, 2010 | 03:05 PM
jwog666's Avatar
jwog666
sounds like the wire on the radio that you thought was a ground is actually the power for the radio lights when the headlamps are on. this will cause power to back feed and alot of weird problems. remove the tach ground and reground to something metal.
Old Apr 24, 2010 | 08:55 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
first unhook the tac and see if issue returns to normal state, if not it is just coincidence and I'd try replacing the flasher, if that doesn't cure the issue, look for a shorted bulb socket or bulb on that side
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
mrappe
Sep 26, 2015 10:16 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
Emblazoned
Sep 3, 2015 10:45 PM
