Track Results
Track Results
Spraying an 80 shot out of the hole .. The car cut a 1.53 60' .. it has a UPR drag launch kit with an air bag .. Im using a 3:55 gear right now on a 26" et street going into 4th gear about 20-30' before the traps .. I want to stay with a 26" tire but I think I need a steeper gear ... 4:10 too much? I also need a line lock .. burnouts suck without wheel speed .. Need to be doing them in 2nd gear ..
Tell me what you learn from this video .. criticize away my friends ..
That is a REALLY good short time good job man ! And I think if you went with a 410 gear that would be too much since you will be closer to topping out in 4th gear. I think a 373 gear would be PERFECT for you. I run 373's and when I cross the traps I am right at 5500 or 6k in 4th gear.
I have 26" tires and 4.10's
you would be above 6,000rpm's in forth with a T5. Probaby at 6500rpms, im unsure.
Your best bet would probably be 4.10's with a 27"-28" tire.
or 3.73's if your dead set on 26" tires, but you are leaving a bit of gear on the table, but that also gives you room to grow when the car gets faster;more power
Orlando is my home town, I miss it sometimes.
My 08 made over 550 to the tire and those tires worked very well .. Though I had a line lock on it and was ablbe to do a 2nd gear burnout .. Right now on this car I am limited to 1st gear burnouts and I cant get enough heat in the tire without more wheel speed ..
Also if you watch the video in slow motion, the car comes up in the front and then it bottoms out the stock shock in the rear causing the car to do a lil bounce and the rear loses traction at that pont .. Time for adjustable shocks and strut!!!
WHAT'S IT RUN ON JUST THE MOTOR??? also when was that video??? friday test and tune, cause right after that video was posted, I was at orlando speedworld that week watchinf TT on a wednesday....was in Daytona for vacation.........was that a friday or saturday???? I would of just missed you
