New engine ordered :)
Old May 10, 2010 | 05:29 PM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
Default New engine ordered :)
so, the Mustang is mostly for sale now. if anyone wants any parts off it PM me to see what i have.
the IRS is staying for my next Mustang, and im keeping the SRA too. spindles and pretty much everything else that Fox guys want of an SN is up for grabs, i just need to keep the shell and title for a donor vehicle.
with that being said...
the engine for the '33 was ordered today
keep in mind the car only weighs MAYBE 2300lbs WITH my fat *** in it, so i dont need the end-all of engines to be happy...
but what i did get was:
Fordstrokers bare block, .030" over
DSS racing X5 long rod 306 rotating kit (5.400" rod), 6cc TF dome pistons, neutral balance, bearings and Total Seal moly-rings
TF FAC heads 64cc chambers. CR should be about 10.4:1 with a Fel Pro 1011-2 gasket.
TFS 2 cam (i know, not the best. but it and the heads were $1300 on craigslist... plus itll rumble a bit )
Harland Sharp 1.6 roller rockers
Pro Products Hurricane (carb) manifold that ill just port match myself to 1262 gaskets
Comp timing chain, and their BIG *** 16" degree wheel. just because...
Melling HV oil pump
Canton 7qt road race pan and pickup tube
and the new FAST EZ EFI complete set (hence the carb manifold).
Meziere elec. water pump w/ idler. im still using the SN timing cover and front accesories for space purposes...
and some ARP studs and stuff.
and thats it. my bank account is officiallylet me know what you think of the combo, and just an FYI: ill be happy with ~375 crank hp (itll beat that for sure).
a few things i need help with:
what MSD dist. should i get? i want a mech/vac one.
what the hell do i do about ignition chores? i want to get an MSD 6AL, but where from there? do i use the TFI coil from my 95? do i need a regular coil? help here is GREATLY needed lol.
valve covers... i know, i cant decide between the TF tall black ones, or the Ford Racing tall black ones with red lettering. HELP!!!!!!! lol.
anything else im missing or need info on let me know.
sadly, this is probably the end of the 5.0 section for me. ive been spending wayyyyy too much time of ffcobra.com and the next Mustang i build is going to be a New Edge 2000 Cobra R clone with a (relatively speaking) stout 4.6 2V in it.
let me know guys!!!
Old May 10, 2010 | 06:47 PM
kweb288's Avatar
kweb288
aw man! sounds like fun, but make sure you stop back in and say HEEEEEY
Old May 12, 2010 | 01:51 AM
w8less's Avatar
w8less
PM sent i need a couple things
djbigskrilla
Sep 20, 2022 01:04 AM
GimpyHSHS
Aug 29, 2015 06:30 PM
Calizic
Aug 28, 2015 01:46 PM
movielover40
Aug 27, 2015 10:13 PM
Gary Ugarek
Aug 26, 2015 08:41 AM
