Bellhousing Problem
Old May 19, 2010 | 07:08 PM
gt884me's Avatar
gt884me
Default Bellhousing Problem
Ok, I've ran into a problem doing my t-5 swap.....i have a used 94 3.8 t-5 which is in great shape, but i have a 94-95 5.0 bellhousing part # rf-f4zr-6394-ca......i was told this only will work on a 94-95 5.0......is this correct? Also i know for sure my 88gt stock starter will not fit i.e. holes wont line up and wont lay in the seat.....Any info here would be appreciated....Thanks, Jamison
Old May 19, 2010 | 09:16 PM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
to a degree yes...
only working on a 94/95 T5 means you cant bolt up a Fox T5 to it. the reason being the input shaft is around ~.600" longer.
the 94- like 04 V6's all use the same trans as the 94/95 GT so its not gonna be an issue...
Old May 19, 2010 | 10:23 PM
gt884me's Avatar
gt884me
what about the starter issue i have..do i need a starter for a 94gt? How about the clutch fork?.....The bellhousing measures 7 1/2 feet...thanks jamison
Old May 21, 2010 | 08:34 PM
sn95_331_GT_ yellow
everthing needs to be 94/95 specific, EXCEPT the starter which IIRC will work from like 90-up...
i happen to know where you can get all this stuff youre looking for too...
PM me.
Seanam
Oct 4, 2015 10:15 AM
dudeguy421
Sep 24, 2015 11:16 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
