checking push rods and rocker arms
Old Jun 8, 2010 | 04:16 PM
slowmofive089's Avatar
slowmofive089
Default checking push rods and rocker arms
so i got my whole motor done the last thing i need is to set up my valve geometry. i see shim kits are cheap and so are push rods. how do i know what size push rod checker to start with. with 1.7 rr my total lift is .512, so its not a HUGE leap over stock. FR makes .30-.60 shims and that seems to be common. but what should the contact spot of the rod and arm look like?-thanks guys
Old Jun 8, 2010 | 08:16 PM
goathead75's Avatar
goathead75
Get an adjustable pushrod and measure the proper length. Set it at the stock length and roll the motor over to see where it rides on the valve stem and adjust from there. The ideal contact spot should be a thin line right on the center of the valve stem. Mark it with a sharpie before you crank the motor over and you'll see where it rides.
Old Jun 8, 2010 | 10:19 PM
slowmofive089
why thank you goat head..i did some searching of the inter web and found some good info... i just want every thing to be right after dumping close to 1500 in just this motor.
Old Jun 9, 2010 | 11:23 AM
Venomantidote95's Avatar
Venomantidote95
Depending on the heads you will prolly use the 6.25 stock length pushrods!
Old Jun 9, 2010 | 11:54 AM
slowmofive089
i got ported gt40's...so i "should" be good with the stock length push rods, with or with the need for shims?
Old Jun 9, 2010 | 01:22 PM
goathead75's Avatar
goathead75
Definitely check them, I have Windsor Jr. heads which should have been fine with stock push rods but I needed 6.345.
Old Jun 10, 2010 | 11:39 AM
Venomantidote95
Well did you get a 6.345??? i didnt think so! you have a choice of 6.25, 6.3 or 6.5! adjustable rockers go along way! If you found a 6.345 enlighten me where i can get the exact preicise pushrods!
Old Jun 10, 2010 | 02:08 PM
goathead75's Avatar
goathead75
Well apparently you don't think. Do your homework before you make stupid posts. You can get them either custom made to that length or Manley has 6.35. Talk to a machine shop or engine builder before you spew stupidity on the internet. http://www.manleyperformance.com/dl/2010/pushrods.pdf
copestang
Oct 11, 2015 07:17 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Dragonus18
Sep 9, 2015 01:21 AM
RWHEELS
Sep 5, 2015 03:42 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
