Inline fuel pump
Old Jun 15, 2010 | 08:05 PM
r390g's Avatar
r390g
Question Inline fuel pump
1993 fox with many mods. Just want to know exactly how to install an inline fuel pump as support for the one in my tank. Yes that would be a total of TWO pumps but i need it that way.
Old Jun 15, 2010 | 10:54 PM
AdderMk2's Avatar
AdderMk2
Banned
not gonna get any help being cocky about your car.
I'd like to know what you have done that makes you think you NEED a inline pump.
Old Jun 16, 2010 | 01:15 AM
luckythirteen13's Avatar
luckythirteen13
+1, a 255lph in tank pump will feed enough hp to split the block.
Old Jun 16, 2010 | 08:32 AM
kweb288's Avatar
kweb288
its really simple to install.... Just go to anderson ford motorsports and get there BIG inline pump kit....
But as stated, whats done to the car? how much power are you making to warrent this type of system
Old Jun 16, 2010 | 10:44 AM
r390g's Avatar
r390g
Well ok im sry. Just gets old saying every last part over and over. Didn't mean to sound cocky. I have a 93 fox but i went with a 351 stroked to a 427. Kept it fuel injected and I didn't do anything to the fuel system before but when I dropped the tank to put a better pump in I saw that the pigtail had been changed. Wireing is old and just wanted to redo it all for peace of mind. The wires were inside the tank after all. Who ever did it before me did a very ****ty job. I wonder how i didnt blow up. Any how I looked into it and one of my buddies whos got 95 with a blower told me about his inline pump and that if I didnt want to do all that in-tank crap that I could just get a pick up tube and run an inline pump.
H/C/I combo, BBK SSI-R, all the bolt ons, Fuel rails are from aeromotive, regulator as well, 30lb injectors, SCT 90mm MAF, tons of other stuff
Old Jun 16, 2010 | 10:58 AM
r390g's Avatar
r390g
Also I don't know for sure what it makes to the wheels but at the shop it made little over 500 on a stand. They said that was the best it would get with pump gas
Old Jun 16, 2010 | 02:00 PM
kweb288's Avatar
kweb288
might wana consider a WHOLE fuel system, like from glenns performance....
Old Jun 17, 2010 | 10:27 AM
r390g's Avatar
r390g
well screw all that... now i need a rear end >:[
Old Jun 17, 2010 | 10:55 AM
kweb288's Avatar
kweb288
built 8.8 will do just fine with what you have,
-Have the axle tubes straightened and welded to the pumpkin,
-31 spline axles,
-might wana do c clip eliminators
-choose a locker, a spool, or an auburn diff
-diff cover for more support
-bearing rebuild kit
-and gears
Old Jun 17, 2010 | 10:56 AM
luckythirteen13
if its only making 500fwhp, id just run a 255lph pump in the tank. if the wiring is bad, its an easy fix. the pump is about $100 new
