suggestions?
Old Aug 5, 2010 | 11:45 PM
89gtwith3.55s's Avatar
89gtwith3.55s
Default suggestions?
im on a $1500 budget (i know its not that much to work with) and im looking to try to get at least 300+ out of my 89 5.0... it already has full pypes exhaust(shorty headers), u/d pullies, fenderwell cai, 73mm maf, 24lb injectors, 190lph fuel pump, a/c eliminated, clutch fan eliminated (electric fans), aluminum flywheel, full msd ignition(distributor, msd 6al, blaster coil)
all suggestions welcome, if possible id like to do all the work myself thanks =)
Old Aug 6, 2010 | 12:02 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
shop the corral, and you could score a used set of aluminum heads for around 700-800, and a intake and cam and you should be close to 300
Old Aug 6, 2010 | 12:06 AM
89gtwith3.55s
any cam/head suggestions in particular? i have a friend thats getting rid of his trick flow street burner intake i could probly pick that up cheap and how much hp do you think im running now?
Old Aug 6, 2010 | 12:12 AM
mjr46's Avatar
mjr46
look for some tfs heads, I 'm partial to custom cams, but if you are on a tight budget, a tfs cam may complement the combo and do okay
Old Aug 6, 2010 | 12:28 AM
89gtwith3.55s
alright thanks.. what do you think im running now? i know its not much im just curious =)
Old Aug 6, 2010 | 04:38 AM
nitrous_bob's Avatar
nitrous_bob
assuming you have 4.10's already you should be in the low to mid 13 range, probably making 230-240 hp
with the cash you have i'd buy all used......
heads, intake, and nitrous
and thats assuming you have 4.10's, if not get that done first
Old Aug 6, 2010 | 03:18 PM
89gtwith3.55s
i have 3.55s i do too much highway driving for 4.10s =(
Old Aug 7, 2010 | 07:47 AM
nitrous_bob
500 rpm and .25 mpg makes enuff diff VS the ability to lift the tires ????
in that case.... save the $1500 til you get another $1500 and do a turbo kit. sounds like ur only option really
and nix what i sed b4... with only 3.55 your more like mid to high 14's
Old Aug 8, 2010 | 02:21 PM
89gtwith3.55s
if i saved the money, on the stock block what kind of boost would be safe to run? only 60k original miles on it im just asking for my knowledge cause i dont have the money for it now
Old Aug 8, 2010 | 03:04 PM
w8less's Avatar
w8less
9-12psi easy with the right fuel mods and a safe tune and you should see at least 300
