Cam selection for new engine.
Old Nov 15, 2010 | 03:04 PM
Eveready77's Avatar
Eveready77
Default Cam selection for new engine.
Hey fellas, new to this site and i need some advice. I am building a '65 Mustang, I bought a '91 5.0 and T-5 out of a GT. I have had the block bored to a 306, hyperutectic pistons (9.5:1 comp) heads have been pocket ported and larger valves, and bigger springs installed, planning on a Weiand stealth intake and a Holley 600. I'm running long tube Hedman headers, 2.5" exhaust and dynomax mufflers. Will probably end up running a 3.27 - 3:55 ring gear to keep decent hiway manners.I plan on useing this car for a DD, and weekend fun, also want it to be able to make a long road trip if I choose to. What I need help with is picking a cam. I want something that is streetable and not a dog on the bottom end but still comes alive when you stomp on it. From what I've read the Motorsport cams are outdated and not that desireable. I've looked at comp cams magnum 281 and extreme energy 266 but alot of this greek to me. Any opinions, especially those founded from experience rather than "i heard this and my buddy said this works" would be appreciated. This is my first shot at building a Mustang or street car, I've been into building offroad trucks for a while so i'm trying to "tune" my thinking a bit now. Thanks again. -Eveready77
Old Nov 16, 2010 | 02:52 AM
Venomantidote95's Avatar
Venomantidote95
If its a stock head stay around a .500 lift, wont help going any bigger. there are plenty to choose from!
B-cam, E-cam, TFS stage 1, thats about all you would need!
Old Nov 16, 2010 | 08:43 AM
ProTrickVic's Avatar
ProTrickVic
stock HO cam and leave it alone until you start really modding the motor like with different cylinder heads
Old Nov 16, 2010 | 09:54 AM
enix187's Avatar
enix187
Personally I would just go with a b cam, mabye the trick flow, like pro said, you've got a nice mild setup no reason to go after a big cam, if you want more attitude than the stock 5.0 b or e cam
Old Nov 16, 2010 | 10:30 AM
motorman524's Avatar
motorman524
MF Informant
I'm with protrickvic. The stock HO cam is your best bet. No letter cam!! I had an E303 once and it sucked.
Old Nov 16, 2010 | 01:10 PM
67mustang302's Avatar
67mustang302
If you want a cam, get a custom grind. Otherwise stock, or a basic ots cam.
Old Nov 16, 2010 | 11:01 PM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
TFS 1 gets my vote...
Old Nov 17, 2010 | 04:07 PM
mr_velocity's Avatar
mr_velocity
What if he changed the heads to TrickFlow 170s?
Old Nov 17, 2010 | 04:12 PM
ProTrickVic
try again. how about trick flow FAC190's
then get a custom billet hydro roller cam.
Old Nov 17, 2010 | 08:23 PM
sn95_331_GT_ yellow
i wish they offered that head with a smaller chamber to bump up the C R a bit.
or even better offer it in a top end kit, with the TFS 2 cam and a 75mm TFS R series manifold...
