hp estimate?
Old Dec 18, 2010 | 02:10 PM
toplessLx's Avatar
toplessLx
Default hp estimate?
ok i have a 1976 block sixty over with standard stroke and pistons. i have 351 windsor four barrel heads (stock) edlebrock preformer zr2 intake with holley 670 street avenger carb. cam is doug herbert. 490/512 lift i believe. not sure of the duration right now. i was told possibly 350-400 horse. but i dunno. just looking for sugestions
Old Dec 18, 2010 | 03:33 PM
302army187's Avatar
302army187
250-260hp at the tires
Old Dec 18, 2010 | 04:14 PM
frdmstng1986GT's Avatar
frdmstng1986GT
+1. MAYBE 275rwhp if everything on the motor is tuned perfectly and the stars and moon and everything is in line.
Old Dec 18, 2010 | 04:33 PM
302army187's Avatar
302army187
even if the heads/intake was hogged out to the max, it probably wouldn't make more then 280.
IDK who told you 350-400, but you should probably stop listening to them.
Old Dec 18, 2010 | 05:56 PM
gearbanger's Avatar
gearbanger
you would be lucky to get 250 out of it.
Old Dec 18, 2010 | 08:49 PM
toplessLx's Avatar
toplessLx
thanks guys. actually the guy that told me that was an old man. i didnt believe it either. but he claimed to be the 302 guru. haha i normally deal with chevy performance cause its cheaper for my drag cars. so i didnt know.
Old Dec 19, 2010 | 12:28 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
these types of threads are not for the tech section, please post in the proper section, I will move it.
Old Dec 19, 2010 | 03:25 PM
2tonterror's Avatar
2tonterror
With a set of stock 4bbl heads and a set of stock 1976 pistons (which are probably 8:1 compression) you will be lucky to make 200 at the rear wheels.
Old Dec 19, 2010 | 03:48 PM
Blown408's Avatar
Blown408
Do some messaging on the heads and shave them to get your comp. ratio up. It will wake that thing right up. Or put some put some nice flat tops in it with the shaved heads. You need to get that ratio up to make any decent HP out of it.
Old Dec 19, 2010 | 06:29 PM
mjr46's Avatar
mjr46
by the time you shave the heads and port the crap out of the stock small ports and install larger valves for better performance, it'd be cheaper to buy a set of aluminum heads, IMO , I wouldn't waste time with stock cast iron oem heads unless you were under class racing rules
