MAF question?
Old Dec 23, 2010 | 02:56 AM
89 mustang's Avatar
89 mustang
Question MAF question?
ok i have a 80mm MAF brand new that i got from a guy i did some trade with and it dont seem to have a name brand any were on it. all i have is what the sensor says on top.i have looked and i seem to fined difrent answers on this maf like calibrated for 24lbs and 19ns make no sence. so i need some healp here guys
E A B C D F up on top
F81F-12B579-BA
AFH80-60
Old Dec 23, 2010 | 08:08 AM
AdderMk2's Avatar
AdderMk2
Banned
thats not a brand new maf, its out of a 98 ford....
and its not going to work in your car without a tune. regardless of what injectors you run.
Old Dec 23, 2010 | 02:41 PM
89 mustang's Avatar
89 mustang
like what car or truck is it ment to work on? im not trying to use it i just whant to know what its for you know.
Old Dec 23, 2010 | 03:05 PM
frdmstng1986GT's Avatar
frdmstng1986GT
Its a 98 Taurus SHO maf.
Old Dec 24, 2010 | 10:47 PM
nitrous_bob's Avatar
nitrous_bob
how deep in the 10's are you ??? or what hp range are you in that you need a 80 ?
Old Dec 26, 2010 | 02:02 AM
89 mustang's Avatar
89 mustang
ok i see thanks.
nitrous_bob
i better run some 10's lol i have a 347 stroker with trick flow hi port heads trick flow R intake 75 mm tb 50lb injectors 90mm maf 10psi not sure about the hp cuz i still need tuned! what do u think 10? or no 10ns? i did run a 11.78 @ 118mph all motor. 1.98 60 ft
Old Dec 26, 2010 | 07:53 AM
nitrous_bob
10psi......................what do u think 10? or no 10ns?
yeah you should. 10 psi from what blower ???
my buddies 347 is a little less than yours and on an s-trim he dynos 518
and your sixty foot killed your last et, that should be like an 11.20-11.30 run
Old Dec 26, 2010 | 07:35 PM
89 mustang's Avatar
89 mustang
vortech s-trim also. when i ran the 11.78 i was on 30lb injectors tho. ur buddy with the 518hp is that wheel or crank?
Old Dec 26, 2010 | 08:01 PM
nitrous_bob
at the wheels... older 347 build, tfs heads and cobra intake. lots of porting... but yours will be stronger
Old Dec 27, 2010 | 06:57 AM
uedlose's Avatar
uedlose
I got a Pro-M or Pro-Flo Meter if you are looking for one it is a 83mm with a 83# hr curve in it. Comes with filter also.
